400EX brake cable problem
After every weekend of riding my parking brake cable is worn out. I adjust it and it becomes loose by the end of the weekend. Is this normal? Should I keep adjusting it or just deal without a parking brake? If I do keep adjusting it, will it wear out for good?
Well, at least I now know I'm not the only one that was having that problem. What exactly is the cause of it?? I can adjust the park-brake bolt on the brake caliper to where it just barely doesn't hit the pad, tighten everything up, make sure the brake doesn't drag, and it works perfect. Then I go for a ride and at the end of the day it doesn't work worth a darn!! Very irritating, and I can't figure out why this is happening. Is something working it's way loose, or is it somehow causing the pad to wear extremely fast? (I'd think I could drag my rear-brake for the entire ride and not cause that much wear, so that can't be the cause, can it?)
the problem with the parking brake is this........when you adjust your brake, you are simple setting the caliper a certain distance from the rotor. The parking brake works great. Then, you go riding and wear some thickness off your pads.......now you need to move the caliper closer to the rotor again........do you see? I like the parking brake on the new DS 650. It works off the front brakes. Good idea I think. Honda needs to take a look around and change the parking brake design.
There is no way the rear brake pad can wear that much in a single ride. If it did, you would be replacing the pad every 3-4 rides. I'll bet a 6-hour MX race would only wear the pad .01" at MOST, judging by how most automotive brake pads wear. Has to be something else causing the problem.
motorhead,
you might be right, but then again you might be wrong. Maybe you don't use your brakes as much as the rider asking the question. As we all know, muddy and sandy conditions can also increase brake pad wear.
P.S. where are they racing 6 hour long motos?
This is a problem that is common to both Honda, Suzuki, Kaw, and Yamaha that use a disc in the back. You can ride the quad for only 10-30 min and the parking brake will not work on any of these brands. I don't know what the problem is but it is the same on all of them. Take a quad that has a drum brake on the back and you can ride it for 6 months and it will still work.
If you want to like the other person said take it off and buy a block off plate for about $12 and use 1st gear as the parking brake.
