Bear Claws or Blackwaters for Rancher
Old May 26, 2000 | 06:19 PM
XLR8's Avatar
DirtyHowies, how do those blackwaters do in the muddy sections of your ride? P.S. where do you ride?
Old May 26, 2000 | 06:54 PM
tramar's Avatar
I like 28" outlaws.
Old May 26, 2000 | 07:46 PM
therock's Avatar
I have the Bear Claws. They are 4 ply rated and do very well and are holding up to some of the Hard Pack and crush & run gravel roads I ride. They rock crawl real good and mud sling well. I can't see any power robbing that the Specialty Type Mud tires do.
I have some info on them you should know.
There are 2 styles. An early mold number and a new improved mold. They beefed up the lugs on the newer mold. I found this out when I purchased a set of 4 @ OEM sizes. All 25 inch tall. The fronts were shorter. Concerned about the 4x4 drive train I called Kenda USA and explained. They asked me for the mold number on the side wall. It looks like a plate with rivets on each side. They revealed I had an old mold number on the fronts (4899 229) in size 25x8x12. I then noticed that the lugs were narrower and thinner than my rear (mold # 5199 211 in 25x10x12). They sent me 2 newer mold tires (0600 212) and let me keep the others to sell. They now match in height and lug size. Compound is between Medium & Hard leaning to the Medium side.
I run 4psi all the way around so I can play a bit and still have some Cush. They are A little taller than my DunFlops 25s'.
Old May 27, 2000 | 09:12 AM
ranchermark's Avatar
Went with 25X8X12 (FRONT) 25X10X12 (REAR) BEARCLAWS. MOUNTED ON BILLIET ALUMINUM WHEELS. ALL FROM HIGHLIFTER. EXPECT TO HAVE THEM NEXT WEEK. I WILL UPDATE YOU ON WHAT I THINK. THANKS FOR ALL OF THE INPUT
Old May 27, 2000 | 10:36 AM
  #15
dirtyhowies's Avatar
XLR8 i ride in the Wiapourous area about 60 km's from Calgary, beautiful mountains and 1000 km's of trails. As for the B/W in mud they work great ,i am usally the one sent in to drag someone out which has been fun at times when you only let out about 3 feet of cable and you get to see how good that lock diff. works while directing the spay from the B/W which cleans reaaaaal goooood.
Old May 28, 2000 | 04:02 PM
  #16
XLR8's Avatar
Thanx for filling me in dirtyhowies, but now for a few more questions: Where did you get your blackwaters? Do you have a lift kit? If not, do those big tires rub on your fenders? Do you make lockers(someone from calgary does) for a wolverine? If so how much do you sell them for?
P.S. Have you ridden around falls creek area?
Old May 28, 2000 | 04:16 PM
  #17
XLR8 when i bought the bike i had them changed never did try the stock tires. No i don't have a lift and yes they did rub but i trimmed of 1/4 of an inch off the black mud flap right at the corner and no rub now. I do make and sell diff. locks for 159.99 Canadian. Hope this helps
exmotocrosser
Sep 13, 2019 06:12 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
