Foreman 450 select switch question?
Old Aug 9, 2003 | 01:09 AM
Coyotechaser's Avatar
Default Foreman 450 select switch question?
I tried the select switch today. When I had it in 4 wheel drive and I switched it back to 2 wheel drive the 4wd indicator light didn't turn off right away. I think it went off and then back on and then off one of the times. Anyone else have this happen?
When standing still I can just turn the switch off and on, off and on and the light responds normally. While driving in 2 wheel drive it stays off until I switch the 4x4 on and the light comes right on. But as I wrote before, when I turn the 4 wheel drive off the light didn't turn right off.
Old Aug 9, 2003 | 11:57 AM
[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 9, 2003 | 05:28 PM
89rman's Avatar
My Foreman does the same thing, it is normal, the traxlok will not change back to 2 wheel drive untill you slow down or let the RPM's come back down. It has something to do with engine compression braking. I will look at my manual and see exactly what it says about this and try to reply back to you, but it sounds normal.
Old Aug 9, 2003 | 06:39 PM
I've been searching my manual but it only has the basic info. If I stop to take it out of 4 wheel drive then the light goes off although it has blinked on once quickly. I just drove up a hill in 4 wheel drive and on the top it wouldn't (the light) go out for a little while after switching (still moving). Thanks for replying 89rman. I just want to make sure it's normal so if it isn't then I can take it back.
Does the Rincon have the same setup because my neighbor said that his light goes right out?
Old Aug 9, 2003 | 07:22 PM
I think there might be something wrong with it. I was just using it while coming to complete stops to put it in and out. Although the switch was off the light still came on when I started to move. If I stopped then the light would go out. But once I started to move the light would come on again. The light finally went out if I turned the wheels sharp in one direction.
Old Aug 9, 2003 | 07:58 PM
SixtyNine400ex's Avatar
to switch into 2 wheel drive from 4 wheel drive you have to be going like 2 mph or slower due to heavy stress on the transmission when going fast....it is faster for going from 2 wheel drive to 4 wheel drive but i dont know why [img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 9, 2003 | 11:01 PM
bigred250es's Avatar
mine does the same thing there is nothin wrong with the machine dont thin there i called my local honda dealer it noral dsont worry bout it
user493
Aug 13, 2015 12:54 PM
heath legg
Jul 24, 2015 01:01 PM
jayking232003
Jul 23, 2015 05:48 PM
Jul 22, 2015 05:00 AM
