Bent A-frames and bent frames
Old Aug 13, 2003 | 08:04 PM
UNCLETOM's Avatar
Default Bent A-frames and bent frames
Hello,, Has anyone ever hit something like a rock or stump with a 4x4 and bent aframes or the frame itself and if so what did you about it. Does it take much to bend them and do damage to the machine or are they tough enough to withstand the abuse? Tell me your story. Thanks in advance Uncletom
Old Aug 13, 2003 | 08:30 PM
RacinJason's Avatar
Seen the earlier frames breaking when farmers put drop rack baskets that hang off the rear of the quad(to heavy)
We see them bent periodically from a good roll...
the farmers hit the cows with them and thats bent a frame of two
what quad is it exactly?
Old Aug 13, 2003 | 10:03 PM
kford's Avatar
i had a friend bend the frame on a foreman 450. they took it to a body shop (another friend) and put it on the rack and streightend it out. i dont think i would try to bend back a-arms though. i would replace them.
Old Aug 14, 2003 | 12:40 AM
UNCLETOM's Avatar
It is my sons rubicon, he hit a tree stump with the right front. He said that he seen it and got on the brakes and didnt hit it to hard but it is toed out about and inch and a half. He thought he hit the stump with the lower a frame. I measured everything i can with a straight edge and tape measure. I really cant put my finger on a bent part. but there is definately something bent alittle. Sure i can re-set the toe end but the right tire still angles in alittle(caster or camber)at the bottom. I have looked at everything including the frame and i cant find anything by eye that shows bending anywhere.I replaced the bottom aframe and solved nothing. I think now if it is any, it is the top a-frame but not sure. I just thought some one out there may have had expierence on this type of problem. I heard once that if it is toed out the main frame is bent???? Thanks in adavance
Uncletom
Old Aug 14, 2003 | 10:52 AM
kford's Avatar
if its just toed out, and you can find no bends or weld damage, it likely is just the toe. this happens. use a tape measure or string and toe it in. just a hint, if yu center it up, it will ride better than it did before (most hondas seem to have the toe out from the start).
Valder
Nov 28, 2020 07:38 AM
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Albertaboyy
Sep 9, 2015 09:51 AM
meddy0388
Sep 9, 2015 06:41 AM
