300ex rev limiter
Old 08-18-2003, 01:42 PM
dsheola's Avatar
Default 300ex rev limiter
Don't get a white brothers rev limiter because they don't work in under 70 Degree weather. Theres also a big gun rev and a wolf rev limiter that works well. the wolf one you can program your own power curve but its around $400.
Old 08-18-2003, 01:43 PM
dsheola's Avatar
also do you have the header to ur exhaust ? that would make a huge difference, but you'd have to rejet ur carb.
Old 08-18-2003, 01:46 PM
Dirtdog300ex's Avatar
Yes ive got the pipe and silencer. Thanks
Old 08-18-2003, 03:34 PM
Southy's Avatar
dirtdog, is the bracket that you are talking about the stock bracket on the a arms, or is it one that you made yourself. did you have to use the 400ex tie rods also. do you have any pictures of what it looks like. from the way you described it, it sounds like the cure to my problem. any help would be appreciated.
  #15
Old 08-18-2003, 03:47 PM
Yes at the top of the shocks the bracket i made attaches to the stock holes. Yes you half to use the 400ex tie rods
Check this out and see if it helps.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2427938244
DGNAZ
ATV Expeditions
06-22-2017 04:20 PM
Bonzhonda300ex
TheATVSuperStore
09-17-2015 01:21 PM
ScopeZ_
09-13-2015 07:55 AM
Steeldon
09-09-2015 09:38 AM
Steeldon
Utility ATVs
09-05-2015 09:38 PM
Quick Reply: 300ex rev limiter
