concerning sprockets
Old Aug 18, 2003 | 12:52 AM
jed250's Avatar
Default concerning sprockets
I'm wondering if a 300ex will have enough power to pull itself if I change the stock sprocket and put a sprocket in with 2 more teeth...or even 3. What about 5 more? Is it worth it to even put a sprocket in with less teeth than stock so the bike will feel more sporty?
Old Aug 18, 2003 | 10:57 AM
Semms40oz's Avatar
If you are talking about the rear sprocket, adding teeth will make the bike slower but give more torque. My experience with the 300 is that it was too low geared to begin with. With that said i would try going to a smaller rear sprocket by one or two teeth or moving to a 14 tooth front.
Old Aug 18, 2003 | 11:20 AM
jed250's Avatar
I'm talking about adding a new sprocket to the front with more teeth. This way it will have a higher top speed but less power. It would be easier to change the back one though wouldn't it?
Old Aug 18, 2003 | 11:41 AM
Semms40oz's Avatar
thats what i was hoping you were talking about but you will never fit anything over 14 without removing the case saver and even after that i can't see anything over 15 possibly 16 fitting.
Old Aug 18, 2003 | 12:26 PM
Honduki's Avatar
I just went to a 12 tooth front on my 250X and it made it way better for trail riding. I believe you can onlu get a 13, 14, and 15 tooth for the front of a 300EX.
Old Aug 18, 2003 | 11:25 PM
jed250's Avatar
The only reason I want to change the sprockets is that I can have a little more speed. My friend has a Warrior and I know I won't have as much torque as him, but I'd want to beat him in the long run. I'll put a smaller sprocket on the back and go up one tooth on the front. Eventually maybe I can modify the 300ex and give it more horsepower so I can even beat him on take off.
-Jed
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
