Sprocket help need advice
Old Sep 12, 2003 | 04:52 PM
Hondanutcase's Avatar
Default Sprocket help need advice
Would it be better to change the front sprocket or rear sprocket for more low end on my 400ex
Old Sep 12, 2003 | 06:50 PM
RideRed81's Avatar
Front sprocket would be more economical.
Old Sep 15, 2003 | 04:29 PM
witti's Avatar
front sprocket will be cheaper, go down 1 tooth and see how you like it.
Old Sep 15, 2003 | 05:55 PM
NotuRaptor2's Avatar
Go down one tooth in the front if you are into tight trail riding. Get a 13 tooth if you put 22" tires on the back. You can get one from sidewinder for sure.
You would have to go up 3 teeth in the rear to equal going down one tooth on the front. Rear sprockets cost more plus you have to deal with a clearance issue with your skidplate.
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
buddieboy
Dec 9, 2016 05:50 PM
kodiacrunner
Oct 4, 2015 11:52 AM
