Kenda Bear Claw or ITP Mudlites (Warrior)
I was wondering which you would pick for a mud tire? ITP Mudlite or Kenda Bear Claw. And do you speak from experience or just a suggestion? What kind of mud can you get through with these tires?
( meant to put this in Yamaha forum but if you still want to reply i'll apriceate it )
Well, the Mudlites are alot lighter but don't last nearly as long. I have heard that the Bearclaws last a really long time and do great in the mud and other things. It depends on if you do 90% mud, get mudlites, if its some mud and the rest hard pack or gravel get the Bearclaws.
If you really want a mud tire for a sport quad i would go with neither of those. I would pic the mud sharks. That are more flat than rounded which provides for width and stability. Mud sharks seam to be the sporty mud tier along with the maxis sur traks but they are only 2 ply i think.
I have heard that the mudlites are better in mud but also wear worse then the bearclaws. I know from a fact that my bearclaws have great wear and bite. They pull really good most mud except for the thick stuff amd them they don't clean out well. The bearclaws are also a sporty tires that you can slide around on very easy.
exmotocrosser
09-13-2019 06:12 AM
