/sigh im such a idiot i broke my bolt off in the oil filter cover
Old Nov 21, 2003 | 10:10 PM
400quad's Avatar
Default /sigh im such a idiot i broke my bolt off in the oil filter cover
thread title says it all, while putting my oil filter cover back on i twisted the bolt on too tight and it broke just far enough in where i cant remove the cap and twist it off with some pliars. wtf do i do?
im so bummed, first my clutch screws up and i cant figure out how to get to it, now this. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Nov 22, 2003 | 12:43 AM
250ex's Avatar
drill a small hole in it. doesn't have to be perfectly centered. tap allen wrench in it thats a little to big. use pencil torch that uses butane. they are cheap. a little heat and turn the allen wrench with some pliers.
Old Nov 22, 2003 | 01:01 AM
400quad's Avatar
thank you vewy mucho
Old Nov 22, 2003 | 03:41 AM
BSA's Avatar
BSA
250ex:
I drill and tap to remove bolts I broke the heads off and studs I cannot twist....
Your method with a drill and an allen wrench is much simpler, I wish I had thought of it. Thanks
Old Nov 22, 2003 | 01:44 PM
Cirith's Avatar
i did that with mine, i was able to just get the bolt with my finger nail and twist it out like that. maybe it could work for you too. it would be worth trying before you got into doing a lot of more complacated things.
Old Nov 22, 2003 | 02:35 PM
KaiserSosei's Avatar
done the same thing
Old Nov 24, 2003 | 02:07 AM
swampdonkeykiller's Avatar
If enough of it is sticking out that you can tap on it with a chisel, you can use a sharp flat chisel and a hammer to turn it. Just get on the highest corner sticking out and tap it in a counterclockwise rotation and if it isn't to tight, you should be able to get it. It is kind of hard to explain but works really well if you know how to do it. Otherwise you will have to drill a hole in the stud and use an allen wrench or easy out to remove it carefully. A reverse drill bit works good to.
Old Nov 24, 2003 | 10:57 AM
pungohboy's Avatar
Wow it sounds like those bolts are prety weak. My girlfriend broke mine off on my 400ex while she was changing the oil ( it was the trade off for replacing her brakes) and i was able to back mine out with the small chisel. And lucky for me they are the same bolts on my 86 trx250 parts bike. it really woried me but it is all better now the wierd thing was the bolt wasnt hardly tight when it broke. I would try to back it out first. it would be alot better than drilling it out.
Old Nov 24, 2003 | 11:47 AM
PADZZ's Avatar
Yep, same thing with me. Mine was broken off deep inside. I couldn't get to it. Had to pull the clutch cover off to get to it. Happened when I just got my torque wrench so I figured I'd spec all the bolts after an oil change. Well, after 20-30 change w/o a TW, it broke when torqued to spec.
Old Nov 25, 2003 | 03:14 PM
Just4Kicks's Avatar
I had a similar problem with a different bike. I just bought a set of E-Z Outs. I like the heated allen idea though.
DeFox500
Jul 26, 2015 06:32 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
cSchwartz
Jul 9, 2015 02:43 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
