440ex to 465ex????
Old Dec 6, 2003 | 12:00 AM
420EX's Avatar
Default 440ex to 465ex????
ok i just had a 440 kit installed on my 400ex now i am wondering if when it comes time to rebuild the top end again would it be possible to bore it to a 465 without replacing the sleeve????
Old Dec 6, 2003 | 01:36 AM
fast440's Avatar
I have heard that you can not, but I'm not sure.
Old Dec 6, 2003 | 10:46 AM
whatwasthat's Avatar
with a bore to 465, you will be risking meltdown..what you want to do is keep your 440, and put in a stroker crank. With that crank you can get all different displacements, the most popular being a 465 or 505.
Old Dec 6, 2003 | 02:45 PM
imported_juggalo's Avatar
465 isn't usually a bore job. it usually involves stroking. if you have a 440 sleeve right now chances are your not at an actual 440cc's yet. you probably have a bore or 2 left in the sleeve cuz when you get them their not usually a true 440 until the last bore. call the maker of your piston and your sleeve to make sure.
Old Dec 6, 2003 | 05:59 PM
Daren420's Avatar
Some 465 kits are big bores only. If I remember correctly it was a 92 mm bore. Yes, that figures up to 465. It would require a special sleeve and you have to bore the cases to accomodate the sleeve.
From the little bit I've seen, a big bore 465 is quicker than a 465 stroker. I have had the opportunity to ride a 465 big bore and it is quite a runner. For your purposes, I would say that it would not be worth the money to step up to a 465 big bore because you would be re-doing everything you already have. The stroker would probably be your best bet.
Daren
Old Dec 6, 2003 | 08:17 PM
420EX's Avatar
thanks for all the information, when it comes time to rebuild the top end i'll just keep it a 440, a stroker crank would be nice but i just had a hotrod connecting rod installed and that cost enough
Old Dec 6, 2003 | 08:35 PM
if you wanna freshen up the top end you probably don't even need to bore. just throw a new piston and rings in there and she'll be good as new. thats assuming of course that the sleeve is in good shape
Blodg500RX
May 6, 2001 06:42 PM
mx400exer
Mar 14, 2001 05:08 PM
mhiggins36
Mar 1, 2001 02:00 PM
TopDawg
Oct 27, 2000 08:44 PM
Berch
Sep 4, 2000 01:25 PM
