RINCON tech question??
Old Dec 21, 2003 | 05:58 PM
RedRinconRider's Avatar
Default RINCON tech question??
So what you are saying is to adj. the resistance just rotate the TPS and to measure i assume you would do that at the plug on the TPS itself. I guess that would mean resseting would be a must also. Thanks for the input I am going to check it out this week.
Old Nov 2, 2021 | 02:28 PM
Dragracer2177's Avatar
Default 04 rincon not shifting to high gear
I changed carbs and trying to get the TPS set. I went through the procedure I read and it works until the -- comes up. Then the lines flash. I've repeated the procedure over and over with the same results. Never used a multimeter and not sure how to set it up. HELP!!!! Just started back with 4 wheeling after 40 years of drag racing.
Old Mar 26, 2023 | 11:37 AM
Woody1974's Avatar
Originally Posted by Yellow650Rincon
I have reset the ECM and it does absolutely nothing. They say you reset it after you do mods, I think. If you want to know how to do it, I can tell you how.
hi I was wondering how to reset my ecm
speedbuff
13
Nov 11, 2020 10:16 AM
wendal
Oct 31, 2017 03:31 AM
bigred20653
Oct 2, 2015 10:05 AM
rgjackson
Sep 17, 2015 11:21 AM
blueandy88
Aug 31, 2015 12:42 PM
