rejet?
Old Dec 23, 2003 | 07:38 PM
hondarider300's Avatar
Default rejet?
i think im getting either a white bros. e series with header, or a FMF powercore 4 with the header that it comes with. Will i need to rejet after i put on these mods. and if so do u recomend getting profesionally done or can i do it myself and how? also, which pipe would u recomend? thanks
-300ex
Old Dec 23, 2003 | 07:59 PM
dragracer789's Avatar
Default rejet?
Yes you will have to re-jet after that. You can do it your self its real easy. take the carb. off and take the bottom drain plug off. The main jet will be right there. Take a small socket and unscrew it. Then put the new one in. MAke sure you dont over tighten it or under tighen it! Keep checking the color of the plug to make sure its not lean still. For which pipe.... I would choose the white bros. because accroding to the dyno they make a little bit more tourque and same h/p.
Old Dec 29, 2003 | 04:02 PM
Default rejet?
thanks
Old Dec 29, 2003 | 07:15 PM
2Fast4U400ex's Avatar
Default rejet?
Yeah. What He said
Old Feb 2, 2004 | 06:49 PM
Loster666's Avatar
Default rejet?
2Fast4U400ex
Damn, I saw the pictures of the flames on your bike.. They are great !
Homemade !? ..
Do you know the method to make this easily !? ..
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
cSchwartz
Jul 9, 2015 02:43 PM
Bm400ex
Jun 22, 2015 09:16 AM
quad_300ex
Jan 23, 2000 10:17 PM
