250R Sleeper?
Old Jan 8, 2004 | 06:55 PM
Nicname's Avatar
Default 250R Sleeper?
I recently picked up a decent 86 250R. Instead of restoring it, I am thinking about making it a sleeper, of sorts. I would kinda like to leave it looking ratty, but have it drag pretty strong. So far, this is the parts list:
88 or 89 Honda cylinder with drag porting,
Pro Design Cool head, with race gas dome,
ESR TRX 5 or TRX 11 Pipe
38 or 39 mm carb,
V-Force Reeds,
86 length swingarm.
This setup sounds pretty mild to me, but how does everyone think it will run. I would rather use a Honda cylinder instead of going with a Pro X, I would also like to keep lots of the local Banshee guys scratching their heads! Any Thoughts?
Old Jan 8, 2004 | 07:40 PM
pimp250r's Avatar
that sounds good so far! But in order to get the most out of your reeds and pipe, I'd get a K&N and maybe and outterwear lid for the airbox...it should run awesome imo, you could probably find a good hot rod crank on ebay for it to really spice things up!
Also, do you have the dyno chart for the TRX11? I'd be interested in seeing what it does....
The TRX5 is a good choice....it's an all around better pipe for the trx...and keeps getting better as the rpm's climb
Old Jan 8, 2004 | 08:09 PM
dragracer789's Avatar
Go get a 295 sleeve and have someone put it in. Then send it out to be re ported, and mabey even stroke the crank. Keep the carb, and if it is a 11 pipe then stay with that. Keep the v-force reeds. Dont run to much compression because you will loose top end. If you really want it to be an all out sleeper with the air box then leave th elid off and drill alot of holes in it. If not then buy a uni P.O.D filter.(clamps right on to the end of the carb, and you would have to buy an extention for the filter because of space. ESR makes an extension Then after that you can frocus on tires and gears ect....After all that you will def. be beatin off shees, and making them scratch there heads. If you have anymore questions dont be shy to ask.
Old Jan 9, 2004 | 12:32 PM
Nicname's Avatar
Thanks for posting. I really thought about the 295 sleeve, but have heard of some real troubles with the heads sealing, therefore, I am considering keeping the bore pretty small. Also, I am currently using a K&N with the lid removed. The bike runs pretty strong in its current setup,(80's porting, stock carb, FMF pipe, V-Force reeds). But as soon as I rebuild I hope to be doing alot better. I do not have a dyno chart for the TRX 11 yet, I believe it will be similar to the CT Whale.
Old Jan 9, 2004 | 12:44 PM
NovaLT250R's Avatar
sounds awsome!!!so u want a sleeper???polished parts make it look fast so dont polish it...maby paint the engine...,maby send your top end away to get a newer port job.and keep stock plastic with stock decals...try and make it look completly stock!!!!i love the idea of pulling up beside a banshee and having them laugh at you then drop there jaws in awe at the end of the race when there in ur dust!LOL
scott!
Old Jan 9, 2004 | 12:57 PM
Nicname's Avatar
Actually, the 250 looks worse than stock right now. I just recently got it, so most of the aluminum that is on it is tarnished, the plastic is stained and old looking. The only factory stickers left are the ones down each side of the hood. I have painted the a-arms and swingarm, but the whole machine still rolls on its factory gold wheels. I may be on to something. Basically it looks like a trail bike out of the 80's. I even have an original Answer silencer! Ha ha.
Old Jan 9, 2004 | 01:53 PM
pimp250r's Avatar
those shearer pipes are ugly...but are supposed to be really good for power...could look into those too
the2stroke.com
NovaLT250R's Avatar
haha sounds like it looks pretty dull!i like it...those gold rims are the ultimate touch!!!!lol i have some on my quadracer accualy!is the sticker on the silencer peeling off and all crappy like...lol
Old Jan 9, 2004 | 02:54 PM
pimp250r's Avatar
lol - make sure there are tons of rips in the seat and paint splatters on it...maybe a cracked fender...
Old Jan 9, 2004 | 03:12 PM
NovaLT250R's Avatar
haha yea the ripped seat will be a good touch!and zip tie all the cracks together lol!hey pimp i think were goin over kill on the sleeper thing tho lol...sleeper doesnt exactly mean look like crap lol
scott
