Just bought a 300EX what mods?
Old Jan 12, 2004 | 01:17 AM
fender's Avatar
Default Just bought a 300EX what mods?
First mod is definitely a pipe,did a lot of research and the yoshi works best if noise is not going to be a problem. k&n ,jetting and air box mods.
Old Jan 12, 2004 | 12:04 PM
TeamTaylorRacing's Avatar
IF you want some extra top end speed throw a 14 tooth sproket on the front and maby go down one or two in the back. I chaged the sprokets and I am getting 73 outta it!
Old Jan 13, 2004 | 01:17 AM
300exrider1502's Avatar
when i bought my 300ex i rolled it and changed my filter from a k&n to a uni- i went to an auto parts store and got a k&n recharge kit, i used the oil that was i there to spray my uni. would this work or am i losing power b/c of bad carb flow and stuff like that? would i also b losing ne power by not jetting it like u said 95wolv?? i bought it used from a friend who had the k&n so i dont know if he jetted it. He also had a powercore 2, but didnt jet the carb for it.
I also really want a 14 tooth front sprocket, but my dad wont let me touch my 4 wheeler. if i can convince him to let me get one do i have to increase my intake and exhaust (he wont even let me get a megamax or Q from fmf) (the pipe has to be quiet)
Thanks
Old Jan 14, 2004 | 01:35 AM
i heard that the intake valves for a 300ex were also the ones for a 250x. is this true. they said that they were too small for a 250 let alone a 300
Thanks
Old Jan 14, 2004 | 01:38 AM
  #15
isnt it hard to change the back sprocket TeamTaylorRacing??
Old Jan 14, 2004 | 11:07 AM
  #16
Hey, No it isn't hard at all. All you have to do is.....
1. Take off left hand side tire
2. losen Chain
3. slip chain off sproket
4. unbolt old sproket
5 Bolt new sproket on
6. put chain bak on
7. Tighten chain
8 Put your tire bak on
That is it. About a 15 minute job.
The only thing is that if you go down in teeth you will need to change your chain so that it fits your new sproket
Old Jan 14, 2004 | 11:18 AM
  #17
95wolv's Avatar
One thing I forgot to add about putting a pipe on a 300ex, the aftermarket pipes run very close to the rear fender by the seat, you are even required to move the rear brake master cylinder. Almost every 300ex I have seen with an aftermarket pipe has a melted spot or hole where it runs next to the rear fender by the seat, I got a square of heat tile with adhesive backing,took a pen and marked where the pipe came close to the fender, then took the fender off and generously covered the area with the heat tile. It has been several months,and no burns or melts, I also trimmed off a tiny bit of the side panel by the seat that ran real close to the clamp, just to be safe. My son has put a lot of hard miles and jumps on it with no problems, just make sure to clean the area for the heat tile and wipe with alcohol to make sure no oil or grease keeps the stuff from sticking,and you should have no problems.
Old Jan 16, 2004 | 05:49 PM
  #18
cpformula's Avatar
TTT
Cole Hadden
Jun 15, 2025 09:05 AM
carolinabomb
Jul 26, 2015 08:40 AM
Jul 22, 2015 05:00 AM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
