new grab bar
Old Jan 14, 2004 | 04:56 PM
400quad's Avatar
Default new grab bar
due to my old grab bar getting worn down by the fella i got my 400ex from, i need a new grab bar
now as far as i can tell the grab bar on the 400ex is welded into the frame(part of the frame) how would i replace the grab bar with it part of the frame? weld a new one on, or are there designated areas to bolt on a new bar? thx
Old Jan 14, 2004 | 04:59 PM
AlphaRaptor660R's Avatar
Welded on? Are you sure? The grab bar should just be bolted on...
Old Jan 14, 2004 | 05:07 PM
400EXJumper's Avatar
Nope...They are part of the subframe, so I guess you could say they are welded on. I had a strap wrapped around mine and it came loose and ripped off the back off the grab bar (sub frame). So I made some sleeves and welded it back on and it is stronger than it was before. As far as replacing in with a after market grab bar, they probably bolt to the old grab bar.
Old Jan 14, 2004 | 10:01 PM
Harw's Avatar
PRM they are held on by U bolts.
Old Jan 15, 2004 | 12:03 AM
rh1n08d9's Avatar
You can always cut the end of the subfram/grab bar off, and make some mounts on the sub frame and get a 250r style bar, I am pretty sure that they fit!
95scramblerruben1033
Sep 23, 2015 06:29 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
black_thunder
Sep 20, 2015 10:21 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
PrairieDog126
Sep 12, 2015 05:23 PM
