What kind of oil to use?
Old Jan 14, 2004 | 05:53 PM
4504x4's Avatar
Default What kind of oil to use?
i just bought a 2002 honda foreman es 450 4x4. I was wondering what kind of oil should i use, like what weight and brand? I live in Dallas texas so its not that cold here. Also what kind of differential lube should i use? Are these the only fluids you have to mess with? I don't have a owners manuel so thats why i'm asking this. Thanks in Advance.
Old Jan 14, 2004 | 06:56 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Honda GN4 10W-40 in winter and 20W-50 in summer. Honda hypoid gear oil 80W-90 in the diffs. That is what the owners manual recommends for my Ranchers.
Old Jan 14, 2004 | 08:56 PM
RINCON's Avatar
Amsoil or Belray makes very high quality Synthetic oils. I am running Belray full synthetic oil in my Kodiak, incredible oil. Very expensive however ($15.95 Canadian)
Old Jan 15, 2004 | 12:25 PM
Specta's Avatar
I personally like Valvoline's ATV oil. It has the SF/SG rating that Honda recommends and is also designed and blended for the wet clutches used in ATV's. I use the 10w40 all year. $2.00 a qt.
I use Valvoline SynPower 75-90 full synthetic gear oil in both differentials.
I also use Zerex Extreme Life engine coolant mixed with distilled water for the cooling system.
I also use only Honda oil filters and change the rubber o-rings, gaskets and the aluminum drain plug gaskets every oil change and clean the air filter when it gets dirty.
Old Jan 16, 2004 | 11:11 PM
2Fast4U400ex's Avatar
I only use honda oils. Always do and always will.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 16, 2015 12:13 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
