Adding grease zerks to 250R A-arms.
Old Jan 14, 2004 | 11:49 PM
Troyer23J's Avatar
Default Adding grease zerks to 250R A-arms.
Any advice on adding zerks to a-arms? Would they make a difference? I just want to be sure it stays lubed right.
Old Jan 15, 2004 | 09:01 AM
briansgi's Avatar
The better built A-arms already have grease zerts so yes it's a good idea to add them if your's doesn't already. Your local hardware store will have the grease zerts which are pretty inexpensive. You will need a tap (also at your hardware store) and a drill, drill out a hole and then carefully run your tap through the hole to make the threads. Just make sure your tap is the same thread size as the grease zerts.
Old Jan 15, 2004 | 11:16 AM
Harw's Avatar
If you have a 1987 and up 250r do not put grease zerks in the a arms it is a waste of time just take them apart every now and then and repack them. When you pump grease into the zerks the grease pushes the seals out of the a arms. Then you have to clean the grease out to get he seals back in the a arms.
fredrikrosen
Sep 28, 2015 09:58 PM
2many2ride
Sep 27, 2015 04:35 AM
WilliamBos
Sep 22, 2015 04:07 PM
bigred20653
Sep 19, 2015 02:11 PM
Alex Rodak
Sep 12, 2015 09:39 AM
