starter problems when engine hot
Old Jan 17, 2004 | 11:03 PM
dudey's Avatar
Default starter problems when engine hot
I have an honda trx350 1987 and im having problems starting my engine only when its hot. I don't think its the starter cause it works fine when its cold. But when the engine is really hot, the starter seems to have a hard time turning the engine. One time i had to use the kick start because the starter couldn't turn the engine fast enough to start it. And its not the battery. Maybe a bearing thats going bad?Someone have a clue ? Thanks.
Old Jan 18, 2004 | 01:54 AM
hondabuster's Avatar
Sounds like the brushes, in the starter are worn out.
Old Jan 18, 2004 | 07:10 AM
dzzy's Avatar
ya, could be brushes, used to put them in like popcorn, if the brushes look good, the armature may be shorted, actually it's pretty common for starters to fail with the symptoms you describe
Old Jan 18, 2004 | 07:57 PM
WoodsRuner's Avatar
might also be the starter bushings.
Old Jan 18, 2004 | 08:03 PM
FaStLaNe's Avatar
thats my guess
Old Jan 19, 2004 | 09:36 AM
dzzy's Avatar
Starter bushings? I doubt it very much, never seen that on this model before. BTW, dudey, if you replace your starter, make sure you get the right one. In 87, they used different length starters in the Foreman and standard models.
Old Aug 4, 2007 | 11:07 PM
Eddie42's Avatar
I have a 86 trx350 the starter makes a loud grinding noise when i try to start
it I checked the starter reduction geers and they look good the starter spins
like it should but i can not tell where the noise is comming from
Old Aug 6, 2007 | 09:10 AM
HondaTechnician's Avatar
Your noise it the starter over running clutch. Its on the back of the flywheel.
tiresharkdbb
Sep 3, 2017 02:06 AM
merryman
Jun 15, 2015 02:36 AM
clsharky
Jun 8, 2015 11:38 AM
kevbowe
Jun 1, 2015 01:17 AM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
