question about a 400ex motor
Old Jan 19, 2004 | 03:04 AM
huskerjim's Avatar
Default question about a 400ex motor
I have a 02 400ex with white bro pipe K&N if I just add a cam say stage one hot cam with stock bore 11:1 piston new have the head ported and flowed will I be able to keep up with the newer 400z kxf400 as well is the stage one what I want what is the difference from the 1 to the 2 stage I want to stick with the stock bore to keep money down and reliability up run cooler as well. thx's for your input need help first honda I ever owned to put motor work in.[img]i/expressions/face-icon-small-blush.gif[/img]
Old Jan 19, 2004 | 10:55 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
W/ a stage 2 cam you will have to change the valve springs, w/ a stage 1 you can throw it in and go(maybe have to adjust the valves a little.)
Old Jan 19, 2004 | 10:56 AM
whatwasthat's Avatar
If you are going to go with a hi-comp piston like that, you should go with a stg 2 cam
Hi compression will build more power down low and the stg 2 will provide the over rev you need
Stg 1 cams are usually used for building low-mid range power
And stock valve springs are fine with a stg 2.. i have been using my stg 2 with the stock springs for about 70-100 hours now and no worse for the wear.
If you were going to build an all out rev machine, then i could see the use for h/d springs. But with a rev around 10,000 and not being there constantly, there is not much of a problem with valve float
With you 11:1 stock bore and eithr cam though, you should have no problem with a stock z/kfx
Old Jan 19, 2004 | 04:03 PM
huskerjim's Avatar
sweet guys thanks will help me....
Reactant
Mar 30, 2022 02:08 AM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
