What does everyone ride????¿¿¿¿
Old Jul 3, 2000 | 08:43 PM
  #41
puddding's Avatar
wow.......hang on......same women 300exguy?
Old Jul 3, 2000 | 09:00 PM
  #42
puddding's Avatar
i could only find an 86 when i was looking round, in the end our farm had 3 bikes on the property (one was a wrecker)....all 86 models....i have never seen a 87 or 88 model
the chain problem...is it an o ring chain?....do the adjusters come loose?.....i haven't owned one for a while but can try to help.....
i think i had locking nuts (might have to go to shop and buy two)....to prevent the adjusted nuts coming loose......if the chain is a non o ring type, it will wear faster.....if its cheap it will where in different places in the chain....chain should be adjusted to give 1 3/16 - 1 3/8 inch (30-35mm)free play in the centre between the two sprockets.....what are the srockets like?.....
might pay to post this as a topic in the forum, you might get some answers!
go luck go hard.....feel free to ask if you still have problems....and look after the machine
Old Jul 4, 2000 | 01:25 AM
  #43
300exguy's Avatar
I am b(250rman) but I was banned!!!!!I am probably goinhg to eb banned agian so if U guys see a new name tlaking the same as I do it is me!!!!
Old Jul 4, 2000 | 04:25 AM
  #44
jeepin's Avatar
I ride 86 trx250r wiseco .020 piston boyeson reeds,FMF gold series fatty pipe,power core 2 silencer,DG alloy series nerfs,motion pro twist throttle,motion pro clutch cable,motion pro kill switch,Durablue eliminator 2+2 axle,durablue posi loc axle nut,white bro's white power shcoks with adjustable res's all the way around,Jd performance +2 A-arms,PEP easy pull clutch perch and lever,nac's casesaver,uni filter,152 main jet,porting work,18/11/8 holeshot mx's on mithcell .190 wheels,20/11/9 6 ply razr's on ITP .190 wheels,21/7/10 holeshots on ITP wide off-set .190 wheels,scott grips,braking brake pads.
MY dad rides 87 LT500R wiseco .080 piston,FMF ram valve,DG nerfs,DG front bumper,renthal handlebars,scott grips,porting work,FMF gold series fatty pipe,power core silencer,20/12/10 black waters on ITP .190 wheels.
moded 86 trx250r
moded 87 LT500r
97 300ex
kinda moded 96 warrior
moded 98 jeep wrangler sport 4.0L
98 eddie bauer expedition 5.4L 4wd
moded 94 blazer 5.7L 4wd
www.angelfire.com/me3/fmf86trx250r
Old Jul 4, 2000 | 12:21 PM
  #45
ATV_MAN's Avatar
Pudding,
I got all new sprokets and and a chain in Feb(same time that the breaks where fixed)
I just went out an got new big 4 bolts and i cant get 1 old bolt out...it's stuck
it's not an "O ring" chain.(i'd like to get an "o ring" chain soon) and someone told me that if the back bearings where new the chain would move more but i don't think that's an issue.
Nondem
Feb 22, 2020 12:20 PM
HondaR24
Jul 16, 2015 10:45 AM
honda71
Jul 12, 2015 05:56 AM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
honda71
Jul 8, 2015 02:13 AM
