I need better suspension
Old Jul 4, 2000 | 05:09 PM
94DGblaster's Avatar
I was going to do motor mods, but the shocks on my 300EX totally suck.
The pre-load is cranked on the rear and it bottoms out every time, The fronts, are passable.
What to get?
I've been thinking about a set of 400EX A-arms, works fronts(no res..do i really need it?) for the 400EX, and a Works back with res.
Any other suggetions?
I like the 250R shocks, but i don't want to weld on my frame, i want a total bolt on set up.
Old Jul 4, 2000 | 06:32 PM
stevie's Avatar
Why dont you just go with works triple rates all the way around and maybe put 2 plus a arms on.
Old Jul 4, 2000 | 07:43 PM
puddding's Avatar
search the forums man this topic has been thrashed out already
Old Jul 4, 2000 | 09:59 PM
400EX A-arms would be plus 2 on a 300EX. Does works make a +2 arm, Triple rate spring, no Res. shock for the 300EX?
Will a Works shocks in triple rate in the +2 setup fit on the 400EX A-arms?
I've heard that the 400EX shocks won't fit without welding on a new bracket
I'm confused, i think i am going to have to get the back first, then work on the fronts later. I still have some one level of preload on the Fronts Left. I also have a bent front A-Arm, i just noticed today, its forward about maybe a 1/4 of an inch. It doesn't seem to bother handling.
Is the Works Quad Star for 499 a good shock? It's the only one i see for the 300EX in Dennis Kirk.
Old Jul 4, 2000 | 10:40 PM
stevie's Avatar
Soem one said something bout that there is a company that makes that braket for the 300.
So that all you would really after to buy other than the 400ex parts..
Old Jul 4, 2000 | 10:47 PM
I don't really want to weld on my frame, i guess i can try to find a welding shop and get it done. The bracket is 120, but it would really be worth it, then i could even use 250R a-arms with adjustable camber and 250R shocks!
Old Jul 5, 2000 | 12:07 AM
jeepin's Avatar
I put my stock 250r shocks on my 300ex and they fit.They made the front end sit real high though it looked stupid.I wish I could put my 250r rear shock on my ex.The 300ex has no linkge darn!!
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Nekolai1
Aug 25, 2015 10:04 PM
Mssarabug
Aug 10, 2015 12:56 PM
