Steering stem on 250R
Old Feb 26, 2004 | 12:33 AM
briansgi's Avatar
Default Steering stem on 250R
Try servicehonda's web site, click here for the diagram
then click on the "Steering Shaft" link on the left side.
Old Feb 26, 2004 | 08:47 AM
Troyer23J's Avatar
I have all the stuff in the diagram.
I put it all on the stem, with the exception of the bottom cover, then I can put the stem down into the place its supposed to go and press it all the way down. This may be right, I just thought it seemed like that nut on the bottom would be used to draw it down into the hole, meaning, everything would go in from the top but the nut would go on from the bottom.
Old Mar 12, 2004 | 03:15 PM
LT250SCRIB's Avatar
I recently installed a burgard stem on my 88 R and its pretty much a pressed fit to install the stem into the bearing at the bottem....yes it is a ball bearing. tighten that nut untill the stem quits moving down. On mine it took some effort.
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
