Steering stem on 250R
Old Feb 25, 2004 | 08:33 PM
Troyer23J's Avatar
Default Steering stem on 250R
Hey. On a 250R steering stem, does the bottom part just push down into the reciever hole for it? If so, what is the nut for?
I have mine out of the frame, all bushings and washers (I think) are on it, and the nut is on it. I thought prolly the nut would go on the bottom to draw it into the hole, but if thats the case then I am missing a washer or something. If i just push the whole thing down into the hole, it fits fine.
Is this right?
Old Feb 25, 2004 | 08:40 PM
oldsandman's Avatar
The nut goes uder the bridge flange at the bottom. The stem goes through the hole then from the bottom the nut goes on with a cotter key.
Old Feb 25, 2004 | 09:28 PM
Troyer23J's Avatar
bridge flange?
I must not have that.
Old Feb 25, 2004 | 09:30 PM
oldsandman's Avatar
It's the thing on the bottom of your frame that the threaded end of the stem goes through.
Old Feb 25, 2004 | 09:41 PM
Troyer23J's Avatar
On mine all i have is the hole for the stem, it goes all the way though at the same diameter. The nut does not catch on anything. I can put the nut on and then put the stemm all the way down into place.....
Old Feb 25, 2004 | 09:47 PM
oldsandman's Avatar
okay at the bottom their is a hole. From the underside of the frame their should be a bearing and a washer then the nut and cotter pin.
Old Feb 25, 2004 | 09:52 PM
oldsandman's Avatar
Look at this:Text
Troyer23J's Avatar
I have, from top to bottom, a seal, a bearing, a small spacer thing, another seal over that, then a washer and then the nut.
but the hole is too big for the washer to catch on it. I looked on ronnies.com at the parts diagram and it looks like what i have. I am not slow, but this has me lost
Old Feb 25, 2004 | 11:02 PM
Troyer23J's Avatar
anyone?
Old Feb 25, 2004 | 11:08 PM
oldsandman's Avatar
You've stumped me!?! Post a picture if you can or pm me so you can e-mail a pic for me.
