Slick50 fuel system cleaner in Recon?
Old Jul 10, 2000 | 01:16 AM
HondaLuvr303's Avatar
I want to put Slick50 Fuel System Formula in my Recon. Will this hurt her?
Old Jul 10, 2000 | 01:36 AM
Deej's Avatar
Hurt, probably not!
Help, probably not!
Use a good source of fuel, from clean plastic cans. Fuel additives are a waste of money.
Why would you want to use an additive like this, especially in a new machine? Not required and won't do anything but lighten your pocket book.
DJ
Old Jul 10, 2000 | 01:43 AM
I saw some silver specks in the gas tank. I am paranoid about messing it up.
Old Jul 10, 2000 | 06:21 AM
JRM's Avatar
JRM
yeah, dont use any cleaners in it. just do what deej said
Old Jul 10, 2000 | 09:01 AM
Deej's Avatar
If there is any dirt in the gas tank then the solution is to flush it. An additive won't remove stuff like that. The cleaner additives are targeting varnish build up in the system. You shouldn't be seeing this on a new machine.
If you think it is a problem then there are two ways to solve it. 1. Take the tank off and flush it out or 2. Pull the fuel line off the bottom of the tank, turn the valve to reserve, and run enough fluid through the tank to flush the particles out the bottom (not the ideal way to flush it).
On the other hand. A good in-line filter will pick up particles quite nicely. If you can see the particles, the filter will have no trouble trapping them. Personally I would probably go with solution 2 above, then let the filter get any particles that remain.
Good luck,
DJ
Old Jul 10, 2000 | 03:36 PM
OK, thanks.
STLyamwar
Jul 25, 2020 04:44 AM
COFatboy
May 2, 2020 12:06 AM
Hunter100us
Oct 7, 2015 11:46 PM
house1
Aug 9, 2015 10:49 PM
Aitch
Jul 21, 2015 09:40 PM
