Bleeding rear brakes on 400 ex
Old Jul 11, 2000 | 12:44 AM
K_Fulk's Avatar
I put new pads on the rear of my 400 and after i got them on my pedal had no pressure. What do I need to do to get them working?
Old Jul 11, 2000 | 01:15 AM
JRM's Avatar
JRM
Try pumping them..I hope you didnt loosen the bleed vavle to get the pads in.. just use a screwdriver to pry the old ones apart. To bleed:
1.Fill the resovor
2. pump and HOLD pressure on the brake pedal
3. have someone loosen the bleed screw while you are still holding presssure
4. when the pedial drops, KEEP pressure on pedal until the bleed screw is closed.
5. once the screw is closed re-fill resovor and pump the pedal back up and start over step #2
Do this as many times as needed to remove air form the brake line ( 5-10 times )
Old Jul 11, 2000 | 03:51 PM
WOODRIDER400's Avatar
If you did not open the bleed valve then just pump them like he said. I just put a new set on last night and that is all I had to do.
Old Jul 11, 2000 | 04:16 PM
ATV_MAN's Avatar
I just had a lesson how to bleed my brakes...Do as JRM said and always remember to keep the lever on while you tighten the valve up or air will get right back in there and you'll probably have to start over.
GOOD LUCK!!!
Old Jul 11, 2000 | 10:28 PM
c400ex1234's Avatar
hey i just had to bleed my rear brakes today... if you want instructions from a manual ask me, i can scan them and send them to you. later
Old Jul 12, 2000 | 12:00 AM
K_Fulk's Avatar
Thanks for the replies everybody.I just followed JRM's instructions. And found out it wasn't very hard. I did it about 5 or 6 times and got the air out.
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
