TC Racing 300ex.....please give me some info on
Old Jul 13, 2000 | 04:43 PM
94DGblaster's Avatar
your TC racing 300ex.
what they did, how much it helped and how much it cost.
Thanks
Old Jul 13, 2000 | 05:43 PM
cstark's Avatar
TC motor includes: Wiseco Piston (stock bore) 10.5-1 compression ratio
High Rev Cam with valve springs, heavy duty rocker arms and valve guides.
Ported and Polished head
3 Angle valve job
Black Box - +1500rpm, 3 degree ignition advance
Modified carb bored to 34mm
Heavy Duty Clutch kit
WhiteBrother's E-series Exhaust with 1.5in header pipe
8-1 inch holes in airbox lid, WB powerfilter
20" Holeshot XC Rears on Douglas Red label rims
22" Holeshot XC Fronts on Douglas off-set Red label rims
Renthal Bars(silver)Scott grips(black)
All Red OEM Plastic with 2000 decals
Parking Brake Block-Off
Removed Headlight, tail-light, handlebar shround, mud-guards and tool-box.
12,13,14 tooth Renthal sprockets
I run 100 octane fuel. Change my oil every other ride, or after each race. Oil is synthetic Hondaline 20w-50.
Swing-arm, a-arms and axle are stock. AXIS shocks arrive within the week.(running stock now)
Quad weights 350lbs(give or take a few lbs on any given day)and produces 28rwHP on a dyno.
Speed------I don't care much about top speed, because I never ride at top speed. This is a woods, HareScramble, Cross Country quad. With 14 tooth couter-shaft sprocket.....around 63mph.
I race with a 12, or 13 tooth counter-shaft sprocket depending on the track, and weather conditions.
Future mods include......
18" Holeshot MX for the rear on beadlocks
21" Holeshot for the front
I want too lower the quad for increased stability in cornering.
I am not interested in aftermarket a-arms or axles till I bust a stock one.
Steering damper?
Ask away if you have questions.....I would rather discuss price and money issues through e-mail.
chrisjstark@yahoo.com
Chris 00' TC Racing 300EX
Old Jul 13, 2000 | 06:00 PM
86atc250r's Avatar
Your Axis shocks will lower it for you (my TCS's have at least 3" of sag) as well as make it corner better due to less chassis roll...
As for a steering damper, look into a Scotts or WER unit, either are far superior to the telescopic style advertised in the magazines (PEP, Denton, Muscle, Graydon Proline, etc....)
Old Jul 13, 2000 | 07:36 PM
cstark's Avatar
Thanks for the info Gabe. Comments that come from experiance are always welcome.
Old Jul 13, 2000 | 08:58 PM
AL300EX's Avatar
do you like your engine performance with those mods, i am currenty get those same mods done to mine . does your starter turn that piston ok?
Old Jul 13, 2000 | 11:00 PM
cstark's Avatar
double post
Old Jul 13, 2000 | 11:01 PM
cstark's Avatar
I am very pleased with the engine performance.
I haven't had a problem with the starter. But I haven't tried to cold start(temp under 30 deg) the engine yet.
STLyamwar
Jul 25, 2020 04:44 AM
GregM
Mar 6, 2018 06:53 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
ltrmc02
Jul 22, 2015 04:50 AM
