HELP FROZEN Frozen Choke!!!!
Has anybody had a frozen choke cable? I have a 2002 Rubicon and it seems that every time i ride it in deep water or wash it, my choke cable freezes. Dose anybody have a solution for this? I thought about filling the boot with grease or something like that but don't want it to end up in the carb! I live in northern Alberta Canada so it's cold alot. And this problem causes me alot of grief! [img]i/expressions/face-icon-small-sad.gif[/img]
My 02 Rancher cable was freezing up on me this winter, and of course it acted up on the friday night before a big ride. I didn't have time to buy a cable (they are pretty cheap) so I pulled the cable off of the carb and sprayed ignition drier/sealer into it, letting it soak in and working the cable, then hitting it again,etc. after about ten sprays I let the cable drain and put it back on. That was about 2 months ago and it is working beautifully! I went out to the garage the other day when it was -38 degrees celcius and it still worked like it was 20 above! Just a note to say that the choke cables are cheap, but when you're in a bind, try this. By the way, I tried it with WD-40 beforehand, it didn't work. I think it's a little to thick to soak far enough into the cable.
Most choke cables I have replaced, when a troubled unit comes across my bench, are split where the cable is bonded to the back side of the **** assembly. You're lucky if the moisture hasn't worked its way into the choke plunger in the carb. I would replace the cable, and check for oxidization within the choke bore.
Just my 2¢
----- Gimpster -----
Just my 2¢
i've never had any problem with the choke cable on my foreman, but my grandpa has. nothin bad, it pulled out a little stiff and then wouldnt go back in. just worked it a little and it worked fine. i think that if you jsut use it every once in a while it shouldnt stick. in the winter when it gets down to like 0 degrees, i just pulled the choke whenever i parked it. that way if it froze i would still be able to start it and get it into the shop to work on it. i never had to, but i was jsut thinking ahead.
Wifes 350 had a problem choke ,it would freeze, someone mentioned that it was a problem where the cable was going into the carb, its covered with a small boot. pull the boot up and try some gasline deicer to thew it out and then fill with wd40 to force the moisture out, then replace the boot. did wifes two years ago, no more problem
If you're stuck in the cold, you can always use the primer to get 'em running. Sometimes a clean and lube will fix things, but Gimpster's right too. Lots of times there's something else wrong with the cable. BTW, there's a collet type adjustment under the cable boot with a gnurled kob for adjusting by hand. If you're cable is too hard to pull, or it wants to fall down, try adjusting it.
