How interchangeable are master cylinders?
Old Mar 31, 2004 | 10:57 PM
Troyer23J's Avatar
Default How interchangeable are master cylinders?
Anyone know how interchangeable the front brake master cylinders are? I am thinking of using street bike brakes on my 250R project, but I dont know if I need a matching set of calipers and a master cylinder, or if I can mix them up. I assume it would have to be something close....
Please help....
Thanks.
Old Apr 1, 2004 | 12:45 AM
420EX's Avatar
Any master cylinder will work, I have a suzuki katana master cylinder on mine and i love it! Its even adjustable for finger to lever distance, plus it has a larger resevoir
Old Apr 1, 2004 | 11:05 PM
Doctorturbo's Avatar
GOT BOOST!
Master cylinders and slave cylinder pistons have a specific bore to bore relationship. If you get it out of wack, it will be harder to pull, or easier to pull depending on what piston you get bigger. If you get it too out of wack, your brakes will feel very strange, like a very hard pull, with very little brake. Not a good thing. You could luck out, and get the right size, but then again you could roll snake eyes the first time out and then.........................[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Apr 2, 2004 | 01:44 AM
420EX's Avatar
I would suggest the suzuki gsx600 katana master cylinder and lever, it works perfect and is much firmer than stock.
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
