brake light on a 04 recon 250es
Old Apr 2, 2004 | 11:40 AM
creep's Avatar
Default brake light on a 04 recon 250es
howdy yall..........
i just bought my first atv, a 04 recon es. i want to put a brake light on it but from what i understand the light has to be hooked up to the foot brake, and i am disabled and can not use my legs, is there any other way to hook up the brake light
thanks in advance for any and all replies
creep
Old Apr 3, 2004 | 08:49 AM
gergb's Avatar
Here ya go...
Brake lights for the Recon and Rancher.
The micro switches for the hand brake levers, I got the part numbers from a Honda dealer microfiche.
The switch p/n is 35340-ML4-005.(needed 2 of them 1 for each hand brake @ $11.17 each)
Also needed was...
1 stop switch collar p/n 35345-HF1-830 ($3.78)
1 screw-washer (4x20) p/n 93893-04020-07 ($.55)
1 screw-wasger (4x14) p/n 93893-04014-07 ($.50)
I am too cheap to pay the $100 plus for the "Honda Brakelight Kit" and have already run the wiring and added a "brake light"(actually two side marker lights bolted to my trunk door.) All told it has cost less than $35.00 this way.
I did my brothers Rancher and it has the same place to mount the same switches. I know these switches also fit 2001 Foreman and Rubicon.(Rubicon already has one installed, it is the start in gear switch) There is also a foot brake switch available, but I have not ordered it or installed it yet.
Note: I have only found the "Honda Stop Lamp Kit" listed for the "97-98" Recon and it says "Maine Only" on the microfiche.
I hope these part numbers will help others.
I had 2 different Honda dealers tell me they weren't available so... if anyone needs to know who I ordered these parts from P/M me and I will send you the name and phone number of the dealer.
Here are some pic's of the mounting points and switches. You may have to register,(free), and sign in to see the pics. Hope this helps.
sweaver
11
Aug 18, 2015 03:47 PM
DeFox500
Jul 26, 2015 06:32 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
MNatv89
Jul 7, 2015 11:36 AM
