Rubicon at the dunes, set code 9
Old Apr 5, 2004 | 03:05 AM
JRM's Avatar
JRM
Default Rubicon at the dunes, set code 9
Took the Ruby to the dunes, had fun climbing crazy stuff in 4low floored hanging with my friends Z400 (until he actually tried)
Anyways, on a few nasty hills the ruby dug in and stalled out halfway up, no problems the first two days until the last day, I was floored in D1 at 40MPH and the winds changed my favorete dune, this time it included a G out and the ruby lost speed so fast (free wheel airborne spin from 40 to 0 in less than a second when it landed) it stalled. Uppon re-starting it flashed the display and stuck itself in 3rd gear- used low range to make the hills and high range to limp back to camp
Pulled the code and its code 9..... removed the battery cable for 5 min and its all up and running fine again. The code 9 is still in there, should I be worried?
Old Apr 5, 2004 | 09:23 AM
dzzy's Avatar
Not unless your dash continues to flash when you ride your machine. I don't have access to a manual here, wonder what code 9 is? You can erase the code(s). While the code is being displayed, press both shift buttons at the same time for at least 3 seconds. The memory will store up to two codes and you may have erase each separately.
Old Apr 5, 2004 | 08:15 PM
sparky259's Avatar
ive got a manual for my 03' rubi. the code "9" is a ecm voltage converter circuit. turn the ignition off and on and check the gear position indicator. if it doesnt blink, it was a temporary failure. if it blinks ("-") you have a faulty ecm.
Old Apr 5, 2004 | 08:18 PM
Chilly's Avatar
If I were a Rubicon, I think I'd be ready to flash the "You Gotta Be Kidding " code..
Old Apr 6, 2004 | 04:02 AM
JRM's Avatar
JRM
thanks sparky, no flashing but the code is still there to pull...but it drives like new
Old Apr 7, 2004 | 08:55 PM
sparky259's Avatar
hi bud glad it worked . if you want to erase the code push the up and down shift switches simultaneously for 3 seconds or more while the problem codes is being displayed. when the erasure is completed, the blinking pattern changes to the erasure confirmation blink. turn the ignition off. if you have more problems with the resetting of the ecm give me a yell. good luck!!!!!
Old Apr 7, 2004 | 10:41 PM
dzzy's Avatar
hmm....didn't I hear that somewhere before?
Old Mar 25, 2005 | 02:16 PM
YBRubi's Avatar
Hi, I am having the same problem on a 03 Rubicon, but mine wont go more than the 2nd or 3rd gear...and the display its blinking ( "- - " ) all the time since the time I turned on....I cant go more than 20 mph....what dou you suggest? is there a code to reset or something? where could I check that codes ? on the manual ? thanx for the help in advance....
Old Nov 26, 2024 | 11:38 AM
agsguy's Avatar
I'm having the same issue on my 2001. Flashing 9 times indicating "ECM voltage converter circuit" malfunction. In my case the issue occurred right after after the vehicle was operated without a battery on just the dynamo. Likely the result of battery absence causing the voltage to spike >20 VDC. Which Honda included a capacitor to stabilize the rectifier output for those cases when the battery has failed.
I'm etching the ECM potting compound now to see if I can possibly trace the issue and repair it on the PCB.
Old Nov 27, 2024 | 03:30 AM
Fairly sure the voltage reg would stop the voltage from going over 14.5v even without a battery, though running a vehicle with ECUs without a battery is asking for trouble. I don't use starter boosters on ECU equipped machines for that reason. I guess if resetting the code doesn't work, then a fresh ECU would be needed, unless you can fix the existing one, but circuits are usually well potted.
crummie
Jun 28, 2020 01:54 AM
kadorni
Jan 16, 2008 09:57 PM
gswed
Jul 25, 2007 08:07 AM
badercarma
Feb 16, 2004 06:24 PM
BJones
Jan 2, 2004 12:52 AM
