Is it hard to change a clutch on 86 250r?
Just a thought... make sure your out put shaft isnt striped! Iv had problems with that before. I swore it was the clutch and then i looked and it was striped[img]i/expressions/face-icon-small-shocked.gif[/img] Its the shaft that the counter shaft sprocket goes on. It has 6 teeth. (out put shaft is also known as the countershaft) When your riding it just look down at that piece. (you can see it in the middle of the sproket) Give it some gas and if it spins then its striped. OR, you can just take the sproket off and look at it. Good luck.
cody500ho
14
Aug 14, 2015 05:03 PM
CRamshaw777
Jul 18, 2015 05:46 PM
