clutch problems
Old Apr 11, 2004 | 02:34 PM
250xRKrider's Avatar
Default clutch problems
my 87 honda 250x feels as though it needs a new clutch... i don't have any experience in being able to tell if it does need a new clutch, so i'm wondering what are some of the signs that i would need to replace the clutch...thanx for all of your input. also, if i were to take it apart, what are some signs of wear that i would see on the cluth plates, and even clutch basket, incase that needs to be replaced too? thank you in advance for all of your input.
Old Apr 11, 2004 | 10:19 PM
bump!
Old Apr 12, 2004 | 12:55 AM
Polaris500HO4x4's Avatar
sorry man no one on here knows about clutches very much or they dont care to help i tried to ask a question about my clutch but no one would say anything either
Old Apr 12, 2004 | 09:18 AM
dzzy's Avatar
The first sign would be what's called clutch slippage. You'd probably notice it first in higher gears at higher rpm's. You will be able to hear the engine pick up rpm but you won't be able to feel any acceleration. Kinda like hitting neutral almost but without the mechanical noise. Sometimes you can hear it best when you hit a higher gear, the gear goes in solidly, but the engine just revs without any connection to the drive train. It's like you are being lazy with your clutch lever but you're not. As it becomes more severe, it will begin to happen more often. In it's most severe case, you just won't go anywhere. First thing, a sticky or clutch cable adjusted without any play will make your clutch slip. If all that's good, you are pretty safe to assume you need clutch work. You want to fix it soon because it's possible for the fiber to begin to peel off the plates or just fragment. Trust me when I tell you that you don't want that material floating around your engine. It makes a REAL mess.
Old Apr 12, 2004 | 01:43 PM
dragracer789's Avatar
Another way of telling your clutch has gone bad is if the plates are blue. That means they were slipping and got to hot.
Old Apr 13, 2004 | 02:12 PM
thanks for the input, i'm gonna open er up tomorrow and see if it does indeed need a new one.
Old Apr 13, 2004 | 05:38 PM
Eric250EX's Avatar
it also may just might be the cable or the spring. but i know if its really stiff and wut noght just a rebuild could work? im not much of a clutch man lol (you can tell i never had to or needed to do clutch work befor..)
skinnyr6
Aug 25, 2023 02:18 AM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
