400ex - year they changed cam and carb size.
Old Apr 16, 2004 | 12:52 AM
Sandrider503's Avatar
Default 400ex - year they changed cam and carb size.
Get a WhiteBrothers allaround cam I here that hot cams has a clicking sound I'm very satisfied with all my WhiteBrothers parts very good quality. When you do upgrade your cam make sure you get stroger valve springs I suggest R/D chromoly springs the Kibble White springs are pretty much the same as stock ones. I don't know about the xr400 cam I just recently heard about them. Hope this is helpful.
Old Apr 16, 2004 | 03:24 AM
Ish416's Avatar
I believe that the 38mm carb on the 04 is a typo. The 400 is plenty carburated with the 35.5. Why would they change the cam, that would cost them money. Hot Cams are not worth the money. I have ridden many quads with Hot Cams stage 1 and 2 and there is not any noticable difference over the factory cam. The XR400R cam seemed to be the best all around cam avalible. It has more power at any given rpm than stock, plus it is just a drop in. The White Bros cam is almost a complete rip off too. I sent my factory cam in to get reground to their specs and when I got it back it was no different than when I sent it out. Luckily my friend had just recently rebuilt his XR400R and wanted more low end power so we swapped cams. He got what he wanted, slightly more power off-idle. I got what I wanted more power practically everywhere except just off-idle. The XR cam is fully recommended.
Old Apr 16, 2004 | 09:12 AM
orky4969's Avatar
ok, so if iget the xr cam then, what other things do i need to buy for it.? or can i just get the cam?
Old Apr 16, 2004 | 04:39 PM
cals400ex's Avatar
Originally posted by: Hondanutcase
Originally posted by: cals400ex
do not go out and buy one of those new carbs. i haven't heard of anyone actually proving they updated the carbs. however, you can get your carb bored out to a 38mm for $125 from rocky ridge or $175 from sparks racing.
for a new cam, get a stage 1 hotcam or an xr 400 cam. the stage 1 is a little more aggressive. if you are getting a higher compresssion piston, you can even go mroe aggressive than the stage 1.
Go to the Honda Web site. They show the specs for the 03 and 04. The carb is bigger on the 04.
yes, it is the same part #. that website isn't enough for me to believe it. i talked to my dealer and they said it was the same carb, same part #. then again, i am not saying the dealers know their stuff all the time.
Old Apr 16, 2004 | 04:43 PM
  #15
cals400ex's Avatar
the xr cam will give a little more low end power but the stage 1 will give a little better high end power. i would get the stage 1 but that is just me. you will have plenty of low end power. it will seem like stock but the power band will be more usable. you don't need anything with this cam. you can use stock rockers and springs.
i would probably remove the base gasket under the cylinder and clean the surfaces with acetone and then use the honda high temp sealant with no base gasket. also, i would remove one layer of the 3-layered head gasket. paint both sides of the one layer with high temp paint. then install only the one layered gasket. this will raise your compression so you should probably have more low end power than stock even with one of these mild cams.
Old Apr 17, 2004 | 12:17 AM
  #16
orky4969's Avatar
thanks.
Bm400ex
Jun 22, 2015 09:16 AM
Joe04785
Jun 15, 2015 03:12 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
blaze_master
May 26, 2015 11:18 AM
