Engine bearing
Old May 1, 2004 | 02:02 PM
Loster666's Avatar
Default Engine bearing
Hey !!
I'm currently inspecting the engine bearing that is in the front crankcase...
When it was oiled, after I remove the case, the bearing was not turning rough, not noise and smooth, but if I left it 2 min, than try to turn it, the first time I turn it it was a bit tuff to make it roll ...
Than, I washed the case in part cleaner, and the bearing is rough and it make some noise ...
Do you think the Bearing is bad, or it needs to be tested when oiled!???
Old May 1, 2004 | 02:13 PM
manual's Avatar
Id just replace.... Its gonna save you a gasket if you have to back into it later on.
Old May 1, 2004 | 02:40 PM
SANDMAN430's Avatar
whats that saying better safe than sorry
Old May 1, 2004 | 06:21 PM
Loster666's Avatar
Well ..
I guess there was dust in my part washer, because when I blew air in it, the bearing was rolling right again ...
8]
Ean
Dec 19, 2022 08:48 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
mudpig79
Jul 13, 2015 03:31 PM
clsharky
Jul 13, 2015 02:07 PM
MNatv89
Jul 7, 2015 11:36 AM
