What is the best way to break in my trx450r
Old May 5, 2004 | 03:51 PM
bazerk125's Avatar
Default What is the best way to break in my trx450r
Hello this is my first thread. This is also my first quad. My salesman didn,t tell me ANYTHING!! I dont want to screw anything up on square one!! Any information would be very helpfull. Should I use synthetic?, should I change my filter first oil change?, should i change the oil on both side of the motor?, All that stuff !!! Again any onfo would be great , Thank you!
Old May 5, 2004 | 04:41 PM
Lancester's Avatar
1. Not yet
2. Yes
3. Yes
4. Congrat's......
Old May 5, 2004 | 05:04 PM
hondarider300's Avatar
also when braking in a new quad for the first tank full of gas dont ride it past half throttle, then the next tank dont go past 3/4 throttle. ull be happy u did this later
Old May 5, 2004 | 05:35 PM
bazerk125's Avatar
Also IF anyone could suggest what kind and weight of oil I should run --- 1. crankcase 2. trans ?
thanks again!
Old May 5, 2004 | 06:17 PM
lilthumper's Avatar
I gave mine about 20-30 minutes of soft ride time. I differed the throttle but kept the revs down. I let it go through about 5 heat cycles during this first 20-30 minutes of ride time. Then I gave it hell. I also changed the oil after about 2 hrs ride time. Then gave it hell again.
Old May 5, 2004 | 06:20 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
thanks again!
Read the owners manual. It tells you what oil to use.
Old May 5, 2004 | 06:26 PM
garyc660R's Avatar
Your owners manual will describe how Honda wants the atv broke in.
Old May 5, 2004 | 08:42 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I highly recommend motomans break-in technique! But, if you have already babied the engine, it is probably to late.
http://www.mototuneusa.com/break_in_secrets.htm
You can run DIFERENT oils in your motor and trans, so take advantage of that! Read the article below, and everything that pertains to the CRF, also goes for the 450R. You can run a JASO MB oil in the motor, but you are stuck with JASO MA only in the trans.
http://www.thumperfaq.com/oil.htm
I ride a couple of hours, then change BOTH the trans and motor oil, plus the filter. Then I change again at 10 and 20 hrs. Initially, in the engine use PETROLIUM (DINO, NO SYNTHETICS) OIL ONLY (Honda GN4) FOR THE FIRST 20 HOURS, then after that switch to a slick JASO MB oil (Honda HP4M with Moly, petrolium/synth blend). Run Honda HP Trans Oil in the trans.
01ssls1
Sep 22, 2015 06:50 AM
nastyblaster100
Sep 13, 2015 01:19 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
black798
Sep 9, 2015 07:42 AM
