Still fight the swingarm bolt HELP!
Old May 11, 2004 | 11:24 PM
MidLifeRider's Avatar
Default Still fight the swingarm bolt HELP!
Does anyone have any idea how to remove a froze swingarm bolt where it goes thru the motor? I have tryed heat, rust inhibitor, trying to drive it out. I am going to try to press it out tomorrow with a vise and my last option is to cut out the bolt with a torch... and I really don't want to use a torch on it!
Thanks, Gary
Old May 12, 2004 | 12:56 AM
Sm0k3d's Avatar
DONT cut it with a torch!!! it will make one BIG mess and be hard to do... Also a press isn't the best way either!! that will bend your frame if your not CAREFUL!! My advice is to get a cut off disk and use that... my neighbor used the same thing on his atc250r.
Old May 12, 2004 | 01:43 AM
THEXOTIC1's Avatar
WHat year is the Honda and what model?
Old May 12, 2004 | 08:09 PM
It's a 2000 400ex. I had to cut the bolt with a torch to get the engine out of the frame. I drove out the ends of the bolt on each side of the frame toward the center, that went fine because of the bearings. But now I have the segment of the bolt that is stuck in the motor, I used a cut off tool to cut it pretty much flush to each side of the motor. I had the ends mushroomed out from hitting it with a hammer and flushed them to get it ready to press out. The only thing I am afraid of is busting the case, if I try to press the bolt out. Gary
Old May 12, 2004 | 10:53 PM
Froooo's Avatar
Go & borrow or buy a bushing driver. They come in different sizes & allow you to beat the crap out of the bolt without mushrooming the end of the bolt. Also, I would soak the bolt with wd-40 overnight before attempting this.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Elkaholic
Sep 6, 2015 02:44 PM
