Electronic Shift problems on 2004 Rancher
Old May 14, 2004 | 12:36 PM
IMnAg79's Avatar
Default Electronic Shift problems on 2004 Rancher
I have read about others having trouble with the electronic shift not working..I have read where some say it could be the Angle Sensor (whatever that is)..If so, where is this located on the machine and can it be changed out without taking it in..
For those who have taken theirs in did the dealer replace it without charge..?
thanks in advance..
Old May 14, 2004 | 05:03 PM
IMnAg79's Avatar
I know I cannot be the only one with this problem..What is everyone else doing or done about it..Is your dealer taking care of the problem??
thanks
Old May 14, 2004 | 08:24 PM
dzzy's Avatar
You need to provide more details. Like, are you under factory warranty period? A description of the symptoms you are having. Is your dash flashing on you? There are self diagnostics on the machine that should spot a faulty angle sensor.
Old May 18, 2004 | 09:25 PM
IMnAg79's Avatar
Update..I took it in and sure enough it was the angle sensor..The technician said if it blinks three times that tells you it is the angle sensor..It was covered under warranty (6 months)..
ride safe..
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
Gtsordo
Jul 13, 2015 10:38 PM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
