I think your 400ex is a piece of junk!!!
Old Aug 1, 2000 | 08:08 PM
Dirtddemon's Avatar
i didn't have a subframe prob, but i have noticed that the frame was welded off center from the factory. my left wheel has more camber than the right as in sits closer at the top than the bottom, just though you might want to check
Old Aug 1, 2000 | 09:16 PM
bigal's Avatar
How did you decide your frame was welded off center? My right,(or left I forget)front wheel has more camber than the left, I have measured everything I can think of and can't figure it out. I even checked the a arms for straight. Mine has been wrecked pretty hard a couple of times, but I can't figure out what's bent.
Old Aug 1, 2000 | 09:48 PM
400exrydr's Avatar
My camber is slightly different on either wheel also. I thought I was just seeing things, but now I'll double check. I'll also take a look at my subframe. I don't really understand why Honda felt the need to make the subframe and grab bar all one piece. The 400ex is the only quad to have this.
Old Aug 2, 2000 | 01:51 AM
86atc250r's Avatar
Yep, mine is tweaked somewhat as well as another EX I have here at the house. Never considered it much of a problem though...
Have you checked out any of my new pics (Batavia race track), nothing truly spectacular. Hopefully I will have some from the Lampe track up soon, they should be fairly impressive, we're going to try to do a photo shoot tomorrow (Wednesday).....
Old Aug 3, 2000 | 08:52 PM
  #15
Dirtddemon's Avatar
hey bigal, flip you quad up on the grab bar and look straight at the bottom of the quad, where the steering stem bearing is, you will be able to tell if its tweeked. i never wrecked mine so i was suprised to see this
Old Aug 5, 2000 | 01:09 AM
  #16
o0oHondao0o's Avatar
jeeze you wouldnt think that the weight of a battery would bend the frame!? Thats what it sounds like saying to me, there is no way the battery is going to bend the frame!!!! unless you had a 400lb. battery...
Old Aug 5, 2000 | 01:29 AM
  #17
Stroke9's Avatar
o0oHondao0o,
They’re saying the frame has a factory bend on the battery side of the frame. The bend is necessary to place the battery in the factory location. The factory bend in the frame makes a weak spot that bends even more when stressed.
A permanent fix is to relocate the battery and replace the sub frame with an after market one that has straight tubing on both sides.
Old Aug 5, 2000 | 01:28 PM
  #18
c400ex1234's Avatar
question.... if someone were to hit the grab bar in a 2nd gear wheelie.... could this cause the frame to be bent even more???
Old Aug 8, 2000 | 03:07 AM
  #19
VilentJ's Avatar
Ive never noticed this on my 2000 400EX and I have stood it up on the grab bar from wheelies(alot) rolled it, flipped it, and jumped tha crap out of it. Mine kind of bends up, which is from the wheelies I guess. What do you think?
Old Aug 11, 2000 | 02:56 AM
  #20
emon's Avatar
just don"t be a dum bum and roll it i roll my bike alot and never broke a thing
Oct 10, 2015 10:20 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
