what mods=more bottomend pwr.(450r)
Old Jun 17, 2004 | 07:55 PM
BillyMac's Avatar
Default what mods=more bottomend pwr.(450r)
Looking to boost the low end some. Is there much i can do to help it out a bit?
Old Jun 17, 2004 | 07:59 PM
hondarider300's Avatar
you can take off your air box lid, and put in a new high flow filter. (make sure you rejet) and if you have the money you could buy a new exhaust system
Old Jun 17, 2004 | 08:50 PM
BillyMac's Avatar
How do you know were your jetting needs to be put at with just the air box mod? I'm starting to look at pipes but will probably be a month or so before i by one.
Old Jun 17, 2004 | 09:17 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
A gearing change.
Old Jun 17, 2004 | 09:43 PM
with an airbox mod with a new filter you will probobly go up 1 size jet maybe, but keep in mind that if your increasing your air comming in, it might not work that well unless you have an exhaust pipe to get it out. but you will probobly still see some benifits. also what reconranger said. a gearing chance would help, i know the 450rs are geared a little high
Old Jun 18, 2004 | 03:18 PM
BillyMac's Avatar
I think I'm going to look at a power package deal and just do it all at once. Now i have to decide on what to get!!
Old Jun 18, 2004 | 05:32 PM
briansgi's Avatar
Cheapest solution is to change your gearing, although this is a give and take situation. To increase bottom end performance you will loose some top end speed but that's usually not an issue since not very often you are tapped out unless you play in the sand.
Old Jun 18, 2004 | 05:55 PM
scrambler123's Avatar
higher compression
Old Jun 18, 2004 | 11:51 PM
radfastdude7777777's Avatar
on all of my machines, i went 2 teeth bigger on the rear sprocket
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
