Correct Compression Honda 110
Old Jun 24, 2004 | 02:45 AM
Neworder's Avatar
Default Correct Compression Honda 110
Does anyone know the correct psi of a 1980 honda 110 I have the book but it doesnt say anything about what its supposed to be I am running 120 psi and cannot get it started does that sound like a compresion problem?
Old Jun 24, 2004 | 02:29 PM
PlatinumDogg's Avatar
Your compression seems to be ok, i looked it up and it should be about 156 +/- 14 psi....my old big red had 100 psi and it ran pretty good...so i dont think that is your problem...also you may want to clean out your carb and make sure u have spark, pull the plug out, attach the plug wire back to it, then ground the plug out on the motor, and turn the engine over to see if theres spark G/L
Sean
Old Jun 24, 2004 | 05:01 PM
Doctorturbo's Avatar
GOT BOOST!
Depending on where you live 125 is fine. More than enough to light gas off. Are you getting spark? Give it a shot of ether and see if it pops. If it does, I would look for fuel problems.
Old Jun 24, 2004 | 05:36 PM
Neworder's Avatar
Well I rebuilt the entire engine had some trouble first getting it in time but it does fire for a few seconds then dies i tried spraying starter fluid in it when i pulled the forsaken string it starts to fire every five pulles when i start gasing it up it dies im thinking the electric timeing is outta wack and used the f mark on the flywheel with the point on the crankshaft i could be doing something wrong but just wanted to rule out the compression. maybe i need a new point and condenser because to me its doing the same thing a car does when it has a few fouled spark plugs not sucking any gas in at all it seems to have no effect on it whatsoever anyone else have any ideas? I dont think I have it one wrong stoke ethier when i reverse the timing 180 out the psi drops to 90psi so it must be on the compression stoke thx agian
Clinton Zimmerman
Old Jun 25, 2004 | 12:28 AM
GOT BOOST!
Sounds like fuel issues to me. I would pull the carb down and clean it up real well, put it back together and crank it up. It's really hard to say from far though.
slowgsxr97
Mar 18, 2022 03:40 AM
TheHood
Aug 8, 2015 05:49 PM
NatePerz
Jul 27, 2015 03:27 AM
southbayman
Jul 24, 2015 09:30 AM
ghost civic
Jul 19, 2015 10:13 AM
