Am i Missing something? (PLEASE GIVE ADVICE)
Old 06-26-2004, 01:23 PM
RPMNitromethane's Avatar
Default Am i Missing something? (PLEASE GIVE ADVICE)
I just got my 440 kit in today. When I ordered it they sid it was a matched and balanced set with an 11:1 compression. My problem is I can get the piston to go into the sleeve. The ID bore of the new sleeve is 89mm and the piston OD is 89mm. How could they fit together if they are the same size? Do I need to send them back or does it need to be bored out? Please help me out. thanks
Old 06-26-2004, 09:34 PM
Kimusaby's Avatar
Did you re-sleve your cylinder and bore it to match the piston and rings?
Old 06-27-2004, 02:53 AM
i just took it to the shop. i knew that you had to bore the cylinder out for the new sleeve but i didnt think i had to bore the ID of the new 440 kit sleeve.i figured it would be made to except the piston.
Big bousse
09-26-2015 10:42 AM
SixSpeed5
8
08-02-2015 05:38 PM
bpegram84
07-22-2015 08:15 AM
bpegram84
07-22-2015 08:12 AM
Scottma518
07-10-2015 12:42 AM
Quick Reply: Am i Missing something? (PLEASE GIVE ADVICE)
