'03 Rancher winch install hot wire???
Old Jul 6, 2004 | 09:35 PM
Sweetwater's Avatar
Default '03 Rancher winch install hot wire???
Can anyone tell me the color of the hot wire for splicing into for the install of a 2500 Warn winch? Unfortunately, I don't have a test light to verify. I'd like to get it right the first time. Thanks much.
Joe
Old Jul 7, 2004 | 03:19 AM
yzbluebeast631's Avatar
It just needs to be spliced into a "switched" hot wire. Use one of the red ones coming off of the ignition switch.
Old Feb 16, 2005 | 05:20 PM
12pointbuck's Avatar
The GREEN wire coming out the cigarette lighter behind the plastic in HOT. That's what I connected to.
Old Feb 16, 2005 | 08:42 PM
Gimpster's Avatar
Red with a black stripe should work as keyed ignition power. Or Pink.
Green wire from the accessory socket is a ground wire.
----- Gimpster -----
Old Jan 14, 2007 | 01:00 PM
Best4x4's Avatar
I had the same problem since no one at any of my local Honda ATV dealers had a clue! It's the Pink wire which will give you power only with the ignition switch turned on. The Red/Black wire is hot all the time.
Tad
toonces
Oct 19, 2015 02:21 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Bratman2
Jul 23, 2015 12:36 PM
cornermike
Jul 8, 2015 11:44 PM
