HELP!!! 400EX Wont start
Old Jul 20, 2004 | 01:37 AM
ATVmadman's Avatar
Default HELP!!! 400EX Wont start
clean the carb and make sure the float isnt stuck.
Old Jul 20, 2004 | 01:47 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
adjust your valves while you are at it
Old Jul 20, 2004 | 10:01 AM
Sparkey's Avatar
Did you say it wasn't fireing? Pull the plug, or unplug the plug wire and put a plug in the plug wire. Be sure the plug is grounded and spin the bike over while watching for spark. If you have a good spark then the problem could be timing, fuel or compression. If no spark then check the obvious things first. Kill switch etc. I am not up on your particular machine, but if you get a service manual from some where it should give you some trouble shooting advice.
Old Jul 20, 2004 | 10:04 AM
Sparkey's Avatar
Since you just installed a cam, there is the possibility something came loose, or the timing chain may have jumbed. Check the engine compression, the cam timing, and the valve adjustment. Also look for a bent valve.
DTroyer01
Jul 3, 2015 07:34 AM
Bm400ex
Jun 22, 2015 09:16 AM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
jbertch
Nov 6, 1999 07:07 PM
