Can someone explain rims to me?
Old Jul 19, 2004 | 11:52 PM
reconman2003's Avatar
Default Can someone explain rims to me?
Ive been searching for tires to fit the stock recon rims i have and havent had much luck. I was wondering if someone could explain what the numbers mean(dimension wise-22means?.....) on the the rims and tires.
f-22x7-11
r-22x10-9
thanks in advance
Old Jul 20, 2004 | 12:11 AM
TractorPacker's Avatar
Do you have a balloon?
22 is the tire height, 7 is the width- 11 is the wheel diamater
22 again height, 10 width- 9 wheel diamater
Your front wheels are probably 5 wide and the rears are most likly 8 wide. I hope this helps.
Old Jul 20, 2004 | 12:14 AM
so i could get a 23x10-9 to fit on the stock rear rim without problems besides clearence?
(just using 23 for example.)
Old Jul 20, 2004 | 12:30 AM
howsagearhead250's Avatar
as long as the last number out of the three matches then you will be all set the wheel diameter is what has to be the same
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
fd24
Jan 16, 2019 08:59 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
