jetting
Old Jul 20, 2004 | 11:31 AM
400sEXridr's Avatar
Default jetting
do any of you guys out there have a 400ex w/ an HMF full system? What is your main jet size? I put a 180 in on mine and it was sputtering a little at full throttle and occasionally back firing when i let off the throttle. Does this mean i am running too rich or too lean. Should i go up or down on the jetting? What is the dynojet equivalent of a 180 Keihin jet?
Old Jul 20, 2004 | 11:39 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Default jetting
180 sounds too big.
I'm running a 165 dynojet with an e-series and K&N. Thinking about dropping to a 160.
Most people running a keihin jet are running around 155 with this set-up, give or take. Depends on elevation, temperature and other mods.
Old Jul 20, 2004 | 05:12 PM
hondarider300's Avatar
Default jetting
sounds like ur a little bit too rich, but keep in mind that slight backfireing and popping may be normal when going full throttle and letting off the gas. if its really bad then ur probobly rich.
Old Jul 20, 2004 | 08:01 PM
cals400ex's Avatar
Default jetting
try a Keihin 155 mainjet or around a 148 DJ.
if the bike is backfiring on deceleration, you need to turn your fuel screw out a little bit. try 1/2 turn or so for starters. if you need to go more than 1 full turn out, i would put in a larger slow jet.
Old Jul 20, 2004 | 09:27 PM
speeeedy's Avatar
Default jetting
im still learning so forgive me. but whats a slow jet?
Old Jul 20, 2004 | 11:18 PM
Raptorlegs's Avatar
T Rex Rider
Default jetting
Think he means pilot jet.
You might get away with a 148 DJ if you have a stock intake but that would be the only way. I wouldn't try one that small with the lid off or a vented lid. Better a little rich than a little lean.
Old Jul 21, 2004 | 03:13 AM
cals400ex's Avatar
Default jetting
a 142 DJ is equivalent to a stock 148 keihin jet.
yes, a slow jet is what everyone referrs to as a pilot jet. your stock one is a 38. most people just put in a 40 or 42 for easier starting.
Old Jul 21, 2004 | 10:19 AM
Raptorlegs's Avatar
T Rex Rider
Default jetting
You can't just compare the diameter on the two. They are different lengths.
Old Jul 21, 2004 | 05:21 PM
400EXRiderJeff's Avatar
Default jetting
Where is the fuel screw on the 400?
Old Jul 21, 2004 | 05:32 PM
Raptorlegs's Avatar
T Rex Rider
Default jetting
Adjust the one on the bottom of the carb. It's hard to get to without yanking the entire carb though.
