crankcase breather
Old Aug 6, 2004 | 04:36 PM
400sEXridr's Avatar
Default crankcase breather
Does air go from the filter through the breather tank to the crankcase or vice versa? I got some dirt on the inside of my breather tank. Should i get a new one because i tried cleaning it and its not coming off.
Old Aug 7, 2004 | 01:26 AM
Doctorturbo's Avatar
GOT BOOST!
An engine will always make some blow-by (because of ring seal). The positive pressure comes from the crankcase and go out to vent.
Old Aug 7, 2004 | 02:42 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
If it is dirty, it most likely came up from the engine. Mine has a little crud in it too. The opening for the vent is between the air filter and carb, so there SHOULD be nothing but clean air in there (unless you had an air filter failure). And, it is under negative pressure, so flow should only be one-way, up from the engine.
On my old Warrior, Yamaha ran the vent BEFORE the air filter (ridiculous!). All kind of crud would build up around the opening. The flow should be one-way, so I guess Yamaha didn't worry about it. We all put in in-line filters, just to be sure!
Old Aug 16, 2004 | 10:20 AM
400sEXridr's Avatar
yes some dirt and water did get through the air filter but it didnt go through the carb. It just settled it the tube connecting them. So I should be ok with some dirt in the crankcase breather?
Old Aug 18, 2004 | 04:28 PM
400sEXridr's Avatar
anyone--will i be ok if i have a little dirt in the breather tank until i get a new one
Old Aug 18, 2004 | 04:31 PM
SickRider's Avatar
Should be
Old Aug 18, 2004 | 09:49 PM
WheelieKing's Avatar
I took mine off and got it wet on the inside and I blew compressed air in there and it cleaned out that dirt.
Scooter's Shop
Oct 9, 2015 02:09 PM
KSJOHN
Aug 30, 2015 08:15 AM
QuadCity
Aug 13, 2015 12:58 PM
Captjay
Jul 23, 2015 12:33 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
