HD clutch 4 the 400ex
Old Aug 9, 2004 | 04:01 PM
berner's Avatar
Default HD clutch 4 the 400ex
I have a 00' 400ex with the 440 bore and the 4mm stroke,ported,oversized vales,15:1 compresion,hot cam stage 2, dmc eghuast, and the 39mm fcr. With all that I had a barnett clutch installed and the dang clutch went out after about 4 rides on it. I was wondring if there is a better clutch out there that I can get, cause that is a tad short of ride time on it. Oh, also I have the HD springs but the stock clutch basket, and I am running alcohol and need a good clutch.
Thanx in advance for the replies
Ben
Old Aug 9, 2004 | 04:25 PM
SickRider's Avatar
I like Hinson
Old Aug 9, 2004 | 08:24 PM
Eric250EX's Avatar
a friend of mine recently got a clutch from EPI, i still have the stock clutch. i tried his bike out (400ex) aand man its mutch easier to controlle. check it out here
Old Aug 9, 2004 | 09:47 PM
tprender's Avatar
After I put my 440 kit into my 400 I was going thought clutches about every 6 months. I then went and put in the 8 plate set up and it then lasted over a year and is still going good. If you all ready have a good basket you can have L summers at GT Thender mod the inside and just change springs, steels and fibers is all that you will need.
tysonbully
Sep 28, 2015 02:30 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
jbrewster94
Sep 23, 2015 04:16 PM
