proc circuit 1-4 mounting problem
Old Aug 11, 2004 | 10:43 AM
blasterrider04's Avatar
Default proc circuit 1-4 mounting problem
does antyone own a t-4 for a 400eex if you do should i have recieved a spacer for my pipe to mount to the frame by the tail lite its the hihgest bolt i mean beacause when i recieved mine i bolted it on to the headpipe no prblem and to the lower frame no problem then when i looked at the last hole there was like a 3 inch gap from thr frame and the stock bolt is to short wat should i do
Old Aug 11, 2004 | 02:14 PM
quaddude400's Avatar
I have a fkx400 and i have that same pipe on my bike. On mine there isnt a spacer needed because it went on fine. If anything you should call the place were you bought the pipe from and ask them whats wrong with it. Maybe try putting the bolt your having trouble with on first and see if the other ones will go on.
Old Aug 11, 2004 | 09:14 PM
Ozark38's Avatar
Yes! It was suppose to come with a spacer (about 2") and a longer bolt with washers. I'd be giving them a call.
Old Aug 11, 2004 | 09:29 PM
SickRider's Avatar
Call them! If you got it off ebay or something you're screwed.[img]i/expressions/face-icon-small-frown.gif[/img]
ltrmc02
Jul 22, 2015 04:50 AM
hondarider1234
Jul 21, 2015 11:53 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
cornermike
Jul 8, 2015 11:44 PM
bikedad3
Jul 2, 2015 02:15 AM
