What does it take for a ATC250R (liquid) to go 50 in 300 ft of sand?
Old Aug 12, 2004 | 12:46 AM
phatcat600's Avatar
Default What does it take for a ATC250R (liquid) to go 50 in 300 ft of sand?
My friends banshee goes 55 in 300 ft and I would like to be able to hang with him...but I expect 55 isnt possible on a stock bore 250.
What do stock R's pull?
Is it possible to get enough power out of a stock bore 250? How much power would it take? 250R's are only 290 pounds so it doesnt seem like it would take near as much.
What would I need to go 50?
Old Aug 12, 2004 | 01:51 AM
biggerisbetter's Avatar
50 mph on stock bore can be done pretty easily once you find a good shop or person how knows how to port that engine right,and match it up with a good carb and pipe. The rest will be in the set-up. Your buddy will then be playing catch up to you.
bigger.
Old Aug 12, 2004 | 01:53 AM
phatcat600's Avatar
One of his friends who I dont really know had theirs set p for motocross and it still ran 63, he has a separate drag setup.
Old Aug 12, 2004 | 01:55 AM
phatcat600's Avatar
You see, porting is on that list of things I cant really get done, that involves takin it apart and spendin big bucks. How much would that cost anyway?
Would it be possible without porting?
Old Aug 12, 2004 | 01:57 AM
phatcat600's Avatar
My dad has a machine shop and knows a lot about engines, he was gonna port our 580 but found out its stock porting was so overboard it wasnt worth it. Think he could do any good?
I would relaly have to show him Im serious about modding it though, at this point whenever i talk about performance he says it runs good enough. He probably just says that cuz he has to help me with everything haha.
Old Aug 12, 2004 | 02:03 AM
What are you current mods?
Maybe Debeechman will see this thread and reply. He knows how to make those R's fly!! I am sure he can tell you a couple things to do on your stock head that will make a difference. Set-up is key in 300ft. you can take alot of weight off that machine still,and with a proper suspension set-up you could be very quick, provided you are a decent rider.
bigger.
Old Aug 12, 2004 | 12:44 PM
phatcat600's Avatar
Im all stock now...
Old Aug 12, 2004 | 05:00 PM
phatcat600's Avatar
I hear there is a 295 kit that is just a resleeve to the stock jug. Is this true or am I not understanding this right...
Our 580 blows all the time and we always have to bore and resleeve it, would this be any different to do?
Old Aug 12, 2004 | 05:41 PM
HA2's Avatar
HA2
porting can be around 200 bucks. porting IMO is your best bet. remove your cylinder and have it ported. you also need to keep in mind that your bike is a trike and will need to be setup properly to handle holeshots when it gets any kind of traction as with any bike for that matter making anykind of power and launching hard. aftermarket swing arm alone will cost you more than any porting job unless the swing arm is used
Old Aug 13, 2004 | 12:03 AM
phatcat600's Avatar
Yeah I dont want a swingarm, I dont wanna get to serious.
Im actually thinkin about gettin a esr 310 Kit eventually, 38mm carb, esr trx5 pipe, some kinda aftermarket airbox
but that 310 kit will be a while away...
how much power can you get outta a 310R?
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
black_thunder
Sep 20, 2015 10:21 PM
rawbdiggity
Sep 7, 2015 12:05 PM
lancemll88
Sep 5, 2015 03:16 AM
