ES failure
Old Aug 12, 2004 | 09:07 PM
cantThink's Avatar
Default ES failure
The shift system on my '02 recon es stopped working a couple of days ago. I can get it to work if I take out the manual shifter and jiggle it back and forth. Anyhow I was wondering if there is any common problem like a bad connection or a bad sensor of some sort that I can fix at home or if I should just drop it off at the honda dealer. any advice would be appreciated thnx
Old Aug 12, 2004 | 10:01 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default ES failure
Wow, this has never happened before!
http://forums.atvconnection.com/mess...did/414708.cfm
Old Aug 12, 2004 | 10:26 PM
Loster666's Avatar
Default ES failure
HA hahah ..
Old Aug 14, 2004 | 01:02 PM
hondabuster's Avatar
Default ES failure
The battery could be discharged, charge it up and have it load tested.
Check for proper oil and amount in tranny. If its due for a change....do it.
Do the clutch adjustment, its the nut and screw at the front of the motor case. This will usually get it going again.
Thor
Jul 19, 2002 05:00 AM
shockwave
Mar 15, 2002 10:42 AM
illin8
Oct 16, 2001 10:22 PM
illin8
Oct 12, 2001 10:02 PM
armyman
Nov 21, 1999 11:22 PM
